I have 1.4gb file and i want to cut the ads and join the rest of the movie? is there any tutorial for it?.
Is there a way to capture one hour show without giving a gb file?, i mean, i want a 300 or 400 mb.
thank you.
note: i use WinDvr to capture, queality= better.
https://www.videohelp.com/edit
Choose your weapon....
Are you capturing in .AVI or .MPG??
Yes you can shrink the capture size of your .AVI's by capturing with a different codec. PicVideo seems to be popular with people who have hard drive issues...
Good luck!!!!!!!!!!
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Capturing Widescreen
By simonw2008 in forum Capturing and VCRReplies: 15Last Post: 7th Apr 2008, 14:48 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
