...DVD encoded in tmpgenc in looks fine but in faster motions are blurred, kind of slowed motions, I encoded in high bitrate (6000 average) and search precision high quality...I happens since I reinstall windows xp and changed to NTFS file system..maybe connected?...please help...
Indy
Check to see if the "no motion search...half pixel" is checked under the "quantize matrix" tab. Unchecking this particular box may just solve your problem. Personally, I have never used it due to the description of exactly how it functions (more blurring at higher motion parts).
Look at that article: Configuring TMPGEnc for high-quality, DVD-compliant MPEG-2
Link: http://dvd-hq.info/Compression.html
dlawedor
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 23:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 09:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 08:15 -
Any way to keep TMPGEnc Author 4 from Re-Encoding video ?
By RWANDREWS in forum Authoring (DVD)Replies: 7Last Post: 3rd Mar 2009, 10:43 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 23:23
...DVD encoded in
