Hi,
cce encoding failed: VBR VBV ovf frame# 305 (00:00:10:04) B 89792 max 69803.94 pln 368.00 rel 19988.06 1.29 qsv 1.00->2.00
CCE version is 2.62.
I have this error message whith dvd2svcd when CCE 2.62 encoding some movies ( ntsc 2 pal problème ? ) but it work whith CCE 2.50 ( but i have black border in 4:3 fullscreen around then movie)
Anyone knows this probleme ?![]()
Thank you
I'll tell you what solved this problem for me, it was to do with the color conversion setting under the encoder tab in dvd2svcd in the advanced settings pulldown box.
I previously had it set to convert to yuy2 but decieded that this might cause a loss of quality if my source was different so i set 'No Color Conversion'. Then I started to get the error you described so obviously I changed back to 'Convert To YUY2' - Problem solved.
But I will give you a tip if you are converting to XSVCD or any other Ultra SVCD formats this might also be a problem because of the non-standard bitrate just stick to the SVCD standard most problems you have with SVCD conversion will go away. - Bu the color conversion solved my issue and hopefully yours.
Cheers.
faac: frame decoding failed: Gain control not yet implemented
By vthirteen in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jun 2010, 13:16 -
CCE SP2 number of VBR passes
By DRP in forum Video ConversionReplies: 1Last Post: 25th Oct 2008, 02:53 -
ffmpeg faac frame decode failed
By fobster in forum Video ConversionReplies: 2Last Post: 28th Mar 2008, 07:10 -
vbr passes in cce 2.70 sp
By DSLGuy in forum Video ConversionReplies: 1Last Post: 19th Feb 2008, 23:33 -
Encoding Failed
By hananke in forum ffmpegX general discussionReplies: 5Last Post: 11th Jul 2007, 06:04
