    Sep 2003
    London
    I am new to capturing and I am a little confused about the standard DV PAL resolution. I know it is 720x576, but this is not exactly 4:3, and when I capture video (with a Formac Studio TVR) the image is slightly compressed horizontally, i.e. people look a little thin. Now, you can change the resolution to 768x576, and that gives a correct aspect ratio and everyone looks fine. But, MPEG-2 DVD PAL resolution is also 720x576. Does this mean that it is necessary in all instances to re-scale the captured DV? I know how to do this, and to remove interlacing and all the rest, but a necessary rescaling step seems odd and I am wondering if I am missing something here.
  2. Keep it 720x576, 768X576 is not a valid DVD resolution. DVD players scale it correctly during playback.
    "Terminated!" :firing:
  3. Your "problem" is that the 4:3 ratio is not a ratio of the number of pixels, but of the physical size. And a pixel on a television is not square, but it is square on a computer. So unless your video player adjusts for this, it will look odd when viewed on a computer.
    In short, you have no problem, other than you may want to find a video player for your computer that will adjust for this fact.
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
    Sep 2003
    London
    ok, that makes it all much clearer. Thanks for everyone's help.
    Sep 2003
    London
    Oh, no it doesn't. If I capture video at 720x576 it looks slighly squashed on the computer screen but you are saying that when it is ripped as MPEG-2 and played on a DVD player it will be stretched out to its correct aspect. But what if I have something like a still photo imported into a DV file. It will look fine on the the computer but will it end up being stretched (i.e. flattened) on a TV screen? In other words, is there some stage of the capture-rip-author process that requires compensation for the un-square pixels of a TV?
  6. Yes, although most photo > CD applications will automatically make the adjustments for you.
  7. Originally Posted by mhar4
    Yes, it should look fine on the TV
    yep, it will look strange on the TV. But like energy80s said, many applications convert it automatically. Just make sure yours does.
