I ahve a capture card and DVD burner and software. What I would like to do now is time-capture digitally, video from my DirecTV when I am away from home. Does anyone know of a free application that will allow me to do so? Thanks. Dale
If you can afford a DVD Burner then you can afford to shell out a few more dollars for a decent Personal Video Station (PVS)setup. Thats of course if your capture card is supported. Or do you mean TV Tuner Card? If you want a scheduling program (Electronic Program Guide) and the ability to convert to DVD, I would suggest the WIN PVR 250 and Snapstream. The two will set you back about $179.00 if you buy the two together. No its not free, but it works and is better than a TIVO with all its features. Remote access from your work, streaming over a network, and re-compression for viewing on a Pocket PCor to any type of file you want.
Virtual VCR has support for scheduled recording, and is freeware.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
No Subsciption-free DVR + DVD-Recorder Combo in USA???
By mltwitz in forum DVD & Blu-ray RecordersReplies: 35Last Post: 13th Jan 2011, 22:23 -
Low Cost (Read:Free) Options for DVR-MS/WTV Files
By dj4monie in forum Video ConversionReplies: 4Last Post: 28th Mar 2010, 18:32 -
How do you make Pioneer DVR-115D Region free?
By scan_disk in forum DVD & Blu-ray WritersReplies: 16Last Post: 12th Dec 2008, 22:37 -
Pioneer DVR-115D - Help on Region Free firmware and USB 2.0 use
By FulciLives in forum DVD & Blu-ray WritersReplies: 13Last Post: 4th May 2008, 21:35 -
DVR-S60 Region Free??
By Zentron in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Nov 2007, 07:49
