  1. Hi, I used trina to convert a rm to avi, then used vdub to change the audio and video duratiosn to match, but now the audio is out of synch. is there any way to re-align it?
  2. in virtual dub, under audio, choose interleaving. then edit the number of ms under "audio skew correction", depending on whether your audio is behind or ahead of the video.
    save it again. don't forget to use direct stream copy.
  3. i am having problems loading an MPEG 4 avi file in vdub.
    do you know where i can get a mprg 4 codec file or something
    thanks
