I am just confused enough. I have a Pioneer 104 that will burn at 2x.
Will it burn 4x media, only at the 2x speed, or will I just get coasters ?
I called the Memorex help desk, and they said "Maybe, maybe not, give it a try."
It will most likely only let you burn 4x media at 1x. You can change the firmware to a 2x for all version if you want, but make sure you research the subject first. I am running 1.40 2x for all and have been happy. I can decide whether the media is safe to burn at 2x or not.
thanks. burning at 1x speed is okay for my purpose. So what you are saying is 4x media will work in my burner, ... ?
!!! WARNING !!!!!
By no means even put a new highspeed (4x) DVD-R or DVD-RW into your Pioneer A03(103) or A04(104) or you will destroy the drive !!!!!
Read:
http://www.pioneeraus.com.au/multimedia/dvd/dvd-r_writing_speed.htm
You will first need to update your firmware before should even touch your drive with a 4x-medium.
As you can read from the information supplied by Pioneer after the update of your firmware your Pioneer A03(103) or A04(104) now can record at 2x-speed on 4x-DVD-R-Media. The information is not clear about whether you are able to record the new high-speed DVD-RW also at 2x-speed.
CU
Schmendrick
Pioneer DVD-RW X162 External Burner ???
By blinky88 in forum DVD & Blu-ray WritersReplies: 4Last Post: 9th Aug 2009, 06:03 -
Need to replace burner in Pioneer 220s
By Brent G. in forum MacReplies: 6Last Post: 12th Nov 2008, 17:33 -
I/O errors with my new Pioneer DVR-115D burner
By gshelley61 in forum ComputerReplies: 4Last Post: 12th Jul 2008, 15:25 -
Trouble burning DVD+R DL with Pioneer burner
By RoyGBiv-inRI in forum DVD RippingReplies: 11Last Post: 17th Oct 2007, 11:43 -
Details on Pioneer burner's FW update ?
By Seeker47 in forum DVD & Blu-ray WritersReplies: 2Last Post: 3rd Jul 2007, 03:41
