i opened up an mpeg2 that i know has some corrupt frames in it. i opened the file in the special MPEG2 version of VirtualDub and scanned for unreadable frames. now that virtualdub has done that, how do i save it as the fixed mpeg2 now?
as an alternate solution, maybe somebody can suggest an application that can demux or fix mpeg streams with unreadable frames. (ive tried tmpgenc and dvd lab and both fail at the first corrupt frame).
::EDIT::
just thought i'd clarify. this mpeg2 file is already ripped from a bin/cue with no read errors. i used vcdgear with the 'fix mpeg errors' option checked. the problem seems to be corrupt frames, not so much unreadable frames.
"Today is only yesterdays tomorrow"
i appreciate the guide but that won't work for mpeg2 files unless im missing something
If you use this version of Virtualdub it might.
http://fcchandler.home.comcast.net/stable/"Today is only yesterdays tomorrow" -
No it wont work with virtualdubmod or virtualdubmpeg2 or any virtualdub, because you can't save the the video as mpeg2 using direct stream copy.
MPEG2 to AVI or whatever VirtualDub will use
By bpatters69 in forum Video ConversionReplies: 4Last Post: 1st Nov 2009, 20:19 -
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 02:49 -
Help! VirtualDub video/audio out of sync when enconding MPEG2 to XVID
By kbal in forum Video ConversionReplies: 6Last Post: 19th Dec 2007, 16:05 -
Problem with Virtualdub-MPEG2
By deepakOne in forum Video ConversionReplies: 2Last Post: 5th Oct 2007, 03:35 -
Please Help! Can't Get VirtualDub-MPEG2 file size down!
By dano187 in forum DVD RippingReplies: 2Last Post: 26th Jun 2007, 20:15
