My PS2 will not recognize a VCD, is there any way that I can burn them differently so it will?? thanks
nope, PS2 cant play VCD. you may have to buy a seperate external device (like the one used in PS1 for mpeg decoding)to play VCD
There is no external vcd adapter available for the PS2. It is currently impossible to play vcds on the PS2.
There is a method to convert avi files to pss which will play on the PS2, however this method is strongly disouraged against for a number of reasons. If you want more info about this procedure and its drawbacks just do a forum search, this question literally gets asked about once a week. -
Adam - I strongly disagree, it gets asked at least once a day not once a week!
Ps2 Burning Problem
By waazzaa101 in forum ComputerReplies: 17Last Post: 21st Jun 2012, 20:47 -
Using my UK PS2 in the US
By ob7777777 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 23:36 -
Capturing PS2 Footage
By -ODeN- in forum Capturing and VCRReplies: 3Last Post: 6th Jan 2009, 16:21 -
PS2 Mod Chipping...
By SE14man in forum Newbie / General discussionsReplies: 10Last Post: 20th Jan 2008, 16:38 -
Ps2 to Laptop
By sk8erkho in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2007, 12:31
