  1. I have AC3fix to remove a header out of a file i have after using virtualdub.
    Thing is i cannot get it to work? i understand what i have to do but every time i try to run AC3fix it flashes up on the screen then a blink its gone?
    What am i doing wrong? AC3fix and the file i am using are in the same directory.... which i have read in the forum is the thing to do........
    Anyone know what wrong?
    Cheers......
    D
    Please use the search, I found this direct when searching for ac3fix in this forum
    https://www.videohelp.com/forum/viewtopic.php?p=644178#644178
