When I encode a DVD to SVCD (or VCD) in Forty-TwoDVD-MPPlus with COPY DVD CHAPTERS, the program isn't able to finish the job and remains 'Encoding chapters' after the Encoding Video was done.
Nothing appears in the "Burn this" folder.
Nor does the preview work while encoding SVCD.
Any idea?
Specs:
OsX 10.2.6,
Forty-TwoDVD-MPPlus 1.0.2a,
PAL format,
Forty-Two 1.6.1 works fine.
Results 1 to 12 of 12
Huh, i did one and it works just fine....
Did you install it properly (as described in the .pdf manual?)
The "installers" for forty-two are not just click and install
you 1st have to put the Forty-Two folder into /library/applicationsupport
THEN you must run the build support app, THEN you must copy the app to your HD THEN you must register it.
did you do all of that??? -
Hello galactica,
thanks for your answer.
I did indeed follow the manual. You have to follow the same steps to get 42 working. Registration was easy to.
Has it something to do with "Copy DVD Chapter Marks" or "Convert..."?
Have you tried both?
I wil try "Convert...".
symphy. -
I have always done COPY. which will just mark them the same as on the dvd.
CONVERT implies you would want particular chapter marks, so you put them in at your desired location -
When I try convert, I always have problems.
But maybe I have some additional information that can help. While the message 'Applying chapters' that remains for hours on the screen, a log was generated by the name
ftChapter.crash.log and containts the following information:
Date/Time: 2003-09-14 18:37:39 +0200
OS Version: 10.2.6 (Build 6L60)
Host: Computer-van-USERNAME.local.
Command: ftChapter
PID: 4006
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000006
Thread 0 Crashed:
#0 0x901ac130 in __CFStringCreateImmutableFunnel3
#1 0x9013c354 in CFStringCreateWithSubstring
#2 0x97dffbfc in -[NSCFString substringWithRange:]
#3 0x97e108a0 in -[NSString substringFromIndex:]
#4 0x00003180 in main
#5 0x000026cc in _start
#6 0x0000254c in start
PPC Thread State:
srr0: 0x901ac130 srr1: 0x0000f030 vrsave: 0x00000000
xer: 0x00000000 lr: 0x901ac0a4 ctr: 0x90000e20 mq: 0x00000000
r0: 0x00000000 r1: 0xbffff6a0 r2: 0x84008282 r3: 0x00000000
r4: 0x00000000 r5: 0x00000000 r6: 0x00000000 r7: 0x00000000
r8: 0x00000000 r9: 0x0000000c r10: 0x00000000 r11: 0x00000000
r12: 0x84008282 r13: 0x00000000 r14: 0x00000000 r15: 0x00000000
r16: 0x00000000 r17: 0x00000001 r18: 0x00000000 r19: 0x00000001
r20: 0x00000001 r21: 0x00000000 r22: 0x00000000 r23: 0xa01303fc
r24: 0x901c772a r25: 0x00000000 r26: 0xfffffff6 r27: 0xa01303fc
r28: 0x00000000 r29: 0xa0131c04 r30: 0x00000000 r31: 0x901aba8c
I reinstalled FortyTwoMP+ but the problem remains.
It does not matter wich DVD I try...[/i] -
If you still have this problem after updating to 1.0.3 then please let me know.
sorry guys, have to wait until KiaCherry comes upon this post.
I cant think of an answer.. -
I upgraded to 1.0.3 and the problems are even worse.
Converting to DVD: 42DVD-MP+ crashes immediatly after choosing the TEMP directory. Even no preview file.
Converting to VCD the problems stay the same!
I tried on two different Macs. Both OsX 10.2.8. With different DVD's or DVD folders.
Thanks for showing interest. -
I am told that Kia and Co. are working on the issue and that hopefully it will be resolved soon.
Can you submit a bug report to chris.long@mac.com. With as much info as you can. Also the normal questions, any spaces in the path to the output or temp? DVD or DVD folder info...
I sent as much info as possible to Chris Long (compressed ouput files and log files). Maybe it will help him in developing the next version, and I hope he will react soon.
It would be nice if the problems are solved in version 1.0.4 or so.
42 is easy to use, and delivers good quality. Maybe we can say the same about 42DVD-MP+ in the nearby future. -
I havent received any mail about this yet, unless it was about a different matter. Can you please resend. Just to clarify, Im Chris.
how to convert a mkv with chaptering to DVD?
By axodry in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2010, 06:38 -
How to create chaptering in MKV or Xvid video file ?
By c1steady in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2010, 11:38 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
Forty-Two requiring I install BSD Subsystem on Leopard
By Berkey in forum MacReplies: 6Last Post: 12th Dec 2007, 10:13 -
New DVDx 2.10: shutdown count-down, WMV volume splitting and chaptering...
By Jim@labDV.com in forum DVD RippingReplies: 0Last Post: 31st Jul 2007, 04:31
