Appears the Menumaker won't tolerate not being installed to the default location?
************** Exception Text **************
System.Exception: ProcessRunner::Run(): no such Program: C:\Program Files\Badgersoft\SVCD2DVD\DVDMenuMaker.exe
at g.a(String A_0, String A_1, String A_2, k A_3)
at f.e(Object A_0, EventArgs A_1)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
SVCD2DVD
Assembly Version: 1.5.1336.21117
Win32 Version: 1.5.1336.21117
CodeBase: file:///D:/apps/SVCD2DVD/SVCD2DVD.exe
KarenGuest
KarenGuest
Sorry - didn't have time to look, I see this was partially answered at least in one previous thread: "Tsk, Tsk... another bug"
Hey,
the anwser is simple. No it won't. So what can you do deinstall it and reinstall it in the default directory.Greatings,
Yf -
This has been fixed
Avisynth script built in path variable
By a1s2d3f4 in forum Newbie / General discussionsReplies: 13Last Post: 29th Mar 2018, 19:15 -
cannot save file path too long
By masadar in forum Video ConversionReplies: 8Last Post: 26th Dec 2014, 02:56 -
Project name and path are not taken
By Lehmeier in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2011, 11:53 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43 -
Is this the shortest path or can I combine steps?
By chrishallowell in forum Newbie / General discussionsReplies: 4Last Post: 3rd Nov 2007, 13:37
