Hi There.
I have an openDML AVI file.(non-standard AVI) Is there a tool with which I can convert it to any other standard format like mpeg or QuickTime?
Thanks.
On 2001-10-04 06:58:14, Dana wrote:
Hi There.
Thanks.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
VirtualDub will read and write OpenDML AVIs, you can then frame serve it from VirtualDub an MPEG encoder. The guides for doing this can be found on this site (I think). You could also use AVISynth to feed your MPEG encoder.
It is alleged that TMPGenc can open large (i.e. OpenDML) AVIs but even in the most recent version I have never been able to get this to work properly; it always loses the sound about 10 minutes into the file. -
My miniDV camcorder captures are type 1 OpenDML avi files. I use TMPGenc to extract the audio as a wave file (file/save as/avi file/wav) and then use another tool to encode the audio from the wave file. Have never had a problem with out of sync audio doing it this way.
VirtualDub or TMPGenc can handle the video in an OpenDML avi. But I think VirtualDub can only handle audio in a type 2 OpenDML avi file.
convert OpenDML to .. better format?
By guthrie in forum Video ConversionReplies: 6Last Post: 18th Jun 2011, 11:52 -
What are the benefits/disadavantages of Avi OpenDML?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Mar 2010, 09:58 -
what format to re-convert avi into?
By gizmobently in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2008, 01:23 -
Problem with TMPGEnc and AVI2 (OpenDML AVI)
By Firre in forum Video ConversionReplies: 1Last Post: 24th May 2008, 12:19 -
Exporting AVI from Premiere in exactly the same format as imported AVI?
By JulieCat in forum Newbie / General discussionsReplies: 4Last Post: 8th May 2008, 10:16
