what are the exact instructions for encoding avi to mpeg2 using tmpgenc? want to watch svcd's in my apex dvd. dont understand the instructions in tmpgenc. such as step #2 load the correct svcd template-how do i figure out which template to use on my avi file? step #3 under settings -what should they be at?
depends on your movie length... look under tools/calceletors. fill in length of movie, svcd and what cd-r type u use. The program will tell you what bitrate. In tmpgenc, press the load button and choose the svcd template, (ntsc or pal) then load the unlock template under extras. Then you can change the bitrate to the bitrate you got from the calcelator.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
