I have downloaded a copy of Bad Boys, but it's split into 2. Is there a tool to fuse both files into one?
https://www.videohelp.com/forum/viewtopic.php?t=124514
refer to the section titled "Warez Rules" You may want to be more discreet about what you're working with in the future. Just a friendly suggestion.
No problem, I'm nobody around here, just wanted to give you a heads up. So say you had a couple of home movies *wink wink* that you wanted to put into one single file ... What format are these files? avi, mpeg? this will help folks to provide suggestions on programs that will work in your particular situation.
Virtual Dub
Then use it's built in frameserver to export to your MPEG encoder.
putting it together
By rickb2010 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2010, 15:40 -
Help putting together a DVD
By Keano16 in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2008, 13:56 -
Putting more AUDIO tracks on a CD
By LOWTECH in forum Newbie / General discussionsReplies: 5Last Post: 6th Nov 2007, 09:51 -
Putting 2 videos together?
By phate53 in forum ComputerReplies: 3Last Post: 3rd Jun 2007, 22:21 -
Putting two DVD's into one
By Victor Hen in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2007, 12:09
