I want to get good quality video for home videos encoded to MPEG2 on my DVD. Is there a good rule that I should consider like burn only one hour for the full DVD vs 2 hours for good quality?
make sure your source material is the highest quality is the most importaint thing ..
then use the bit rate calc here to work out your bit rate -- highest quality can be obtained (with good encoder and good source material) at between 4000 - 9000 bit rate .. depending on the type of home material you are encoding .. (pron doesnt require much - but running water requires a lot)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
My file sizes of 2 gigs for 2 hour movies look darn good....Im prolly making them at 3500-4800kbps.....
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
Trying to rip DVD's...... quality is not good.... sugggestions?
By True Colors in forum DVD RippingReplies: 6Last Post: 29th Jan 2010, 11:24 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
ConvertXToDVD....some good reviews, what about DV to DVD quality, etc.
By tmh in forum Video ConversionReplies: 6Last Post: 19th Dec 2007, 14:39 -
6 hours of good quality video on dvd
By gameroftheuk in forum Authoring (DVD)Replies: 1Last Post: 30th Aug 2007, 02:59
