hope i got right forum here so here goes .
i have 7 asf files i want to put on cdr to make a vcd. how can i join them all together to make 1 asf file and how do i get then to play on my dvd player cheers do i need to convert to another format 1st ? if so what and how do i use
thanks
Whether or not they can be converted is an open question. Older ones can, but newer ones with Digital Rights Management are more difficult.
Your jumping into water over your head, in my humble opinion.
Look through the tools section for ASF conversion utility. When your done you should have an AVI that you can convert using standard methods to DVD/VCD/SVCD as needed. Burn as normal.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Cannot play ASF (WMV) files in Windows Media Player
By javaluvva in forum Software PlayingReplies: 3Last Post: 15th Jul 2010, 22:57 -
.asf drm will not play
By powrslave in forum Newbie / General discussionsReplies: 0Last Post: 21st Aug 2009, 19:46 -
WMP11 can't play .asf?
By ChiSholm in forum Software PlayingReplies: 2Last Post: 8th Jan 2009, 08:19 -
facility to examine asf files
By Ogilvy in forum Newbie / General discussionsReplies: 5Last Post: 10th Jan 2008, 06:58 -
Pixellating ASF Files
By camboyedit in forum Video ConversionReplies: 5Last Post: 19th Nov 2007, 09:07
