after i burn a dvd-r, it shows up 0 bytes. i have no idea what the problem is. i used dvd decrypter to do a full rip. i used ifoedit to play the rip and it plays fine. then i use dvd2one to transcode it. again used ifoedit to test play and it shows up fine. then i used nero 6 to burn video_ts folder and after it completes i get a seemingly blank dvd-r that is unplayable. this has happened 3 times, twice with nero, and once with copytodvd. can someone point me in the right direction as to what my problem might be before i burn another coaster? btw i'm using an optorite dd0203 recorder with ritekg04 discs. i tried seaching the forums and came up short. thank you.
update: i just tried imgtools to make an iso file to burn with dvd decrypter and got the same problem. i'm going to lose my mind.
update: i give up.
Results 1 to 15 of 15
i'm positive i'm burning, because the disc has 0 bytes used and 0 bytes free afterwards.
anybody have any ideas what so ever? any comments or suggestions will be appreciated. i've got 5 out of 5 frisbees and counting.
Try backing up a DVD5 disc by creating an ISO file with DVD Decrypter and burning the file to disc (again using DVD Decrypter). If your disc is still blank using this method you probably have a bum burner. A lot of people are having problems with the optorite burner.
like 2man said:
In Nero before you burn check the "compilation info" menu option to see if all your data is there. This will tell you the size of the disc content that you are planning to burn.you must put your final files *.ifo/*.bup/*.vob in VIDEO_TS directory when making a DVD movie files in Nero
Approx burn times are as follows:
A 4x disc should take about 15 min
A 2.4 disc should take about 23 min
A 2x disc should take about 1/2 hour.
A 1x disc about 55 minutes.
This is without post write verification of course and no simulation.
How long do your discs burn?There's not much to do but then I can't do much anyway. -
hardware: amd athlon xp 3000+, asus a7n8x deluxe mobo, 512 pc3200 ddr ram, optorite dd0203 dual burner firmware 2.17, ritek g04 dvd-r discs.Originally Posted by handyguy
software: dvddecrypter v3.1.6.0, dvd2one 1.2.3, nero 6.0.0.15, ifoedit 0.94, imgtools 0.89 and .90b6.
now i just tried to burn the iso file with dvddecrypter on a verbatim datalife dvd+rw (ricohjpnw01) and received the same results with 0 bytes used, but unlike the dvd-r, the rw disc still shows 4.37gb free. i have to head to work right now, so i'll see if i can erase the rw disc and try to burn regular data on it once i get home.
update: i was gonna post this afternoon, but the forums were down. -
all the data is there.Originally Posted by gll99
for my 4x dvd-r burning at 4x, 15 mins. for my 2.4x dvd-rw burning at 2.4x, about 20-25 mins.Originally Posted by gll99
strange thing happened with the dvd-rw. this afternoon, right after i burned it, it was completely unrecognizable by my optorite, but after i came home from work it's being recognized by the drive AND on my apex ad-1200 standalone (a little skipping at times, but playable). can somebody give me a little insight on what is happening here? i'm a newbie, and appreciate all the help so far. thanks. -
i think i may have found my answer here https://www.videohelp.com/forum/viewtopic.php?t=176358. apparently there is an issue with the optorite drive and dvd-r discs. which is great because i bought 100 of 'em.
Empty CD/DVD Spindles???
By rmbean in forum MediaReplies: 5Last Post: 9th Aug 2011, 13:26 -
Ipod says its empty after sync
By Akhet in forum Portable VideoReplies: 23Last Post: 11th Mar 2011, 00:56 -
Vegas - Empty Event
By vegasarian in forum EditingReplies: 1Last Post: 10th Oct 2010, 11:44 -
Empty DVD?
By Han Solo1 in forum Newbie / General discussionsReplies: 28Last Post: 12th Nov 2009, 01:59 -
Empty file
By begeta50 in forum ffmpegX general discussionReplies: 7Last Post: 23rd Jul 2009, 13:17
