I've been backing up dual layer dvd movies to DVD-R for a while now w/o any problem using DVD2ONE and DvdXcopy. However when it comes to Data DVD I am a bit at loss since it seems to be done differently.
I want to backup a DAtA DVD which contains Microsoft Official Curriculum (MOC) Trainer KIts. There is approx. 8 GIG of data on the dual layer dvd spreaded among 20 data folders and one VIDEO_TS folder (200 mb) for a short movie presentation. There are also 5 files located at the root level of the dvd.
I copied the whole thing to my HDD and used Instant CD/DVD to burn the first half of the data folders to one DVD-R and the second half to another DVD-R and I included the VIDEO_TS along with the root files on both DVD-Rs.
The first DVD-R works fine and I can access the folders structure using the proprietary interface, however with the second one I can see the folders structure but can't access them. I think the problem may come from the fact that some pointers may not be maintained properly through the folders structure when dividing the data among the two DVD-Rs.
What program should I use to deal specifically with dual layer data dvds ?
or Is there a special procedure to follow in these cases ?
Where ever you go... there you are...in dvdland
how are dual layer dvds read?
By dblake2 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 6th Jul 2012, 12:51 -
data on dual layer dvd disc......
By dvstorm in forum MediaReplies: 4Last Post: 23rd Feb 2009, 20:21 -
Formatting dual layer DVDs before recording?
By Emmabarn in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2009, 23:10 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
what dual layer dvds should I be using with the following setup?
By transient_today in forum MacReplies: 1Last Post: 22nd Jul 2007, 16:05
