  1. What is the difference between video direct stream copying and audio direct stream copying and video and audio full processing mode?
    Also where do i goto to strip the audio with vitrualdub WITHOUT changing the audio format. The audio is AC3 which is what i want it to stay as, not WAV.
    Many thanks......
    D
    from the virtualdub help
    Video processing modes
    VirtualDub has four video processing modes. They are, as follows:
    1. Direct stream copy
    In this mode, video data is copied directly from input to output without any processing.
    Advantages:
    ·Fastest mode; as fast as 400fps with many input files.
    ·No quality loss.
    Disadvantages:
    ·Processing must begin on a keyframe.
    ·All frames in the range must be copied (no decimation).
    ·The video cannot be seen.
    2.Fast repack
    Fast repack mode allows a video stream to be recompressed. In this mode, VirtualDub hooks decompressor directly to compressor and tries to find the fastest way from one video format to another.
    Advantages:
    ·Depending on the video codecs involved, recompression might take place in a faster format, such as YUV. This can significantly speed recompression.
    Disadvantages:
    ·May not work if the codecs cannot agree on a common image format.
    ·Video cannot be viewed during process.
    ·No image processing possible.
    ·Some video codecs handle YUV data incorrectly, which can result in upside-down video in this mode.
    3.Slow repack
    VirtualDub decompresses the input video to RGB and compresses it using the selected video compressor.
    Advantages:
    ·Allows a video stream to be recompressed from any video format to any other, provided compressors and decompressors are available.
    ·Compatible with more video codecs, because RGB is a very ‘safe’ format.
    Disadvantages:
    ·Often slower than fast repack mode.
    ·Compressors and decompressors must be compatible; if the decompressor only decompresses to 16-bit RGB, and the compressor only accepts 24-bit RGB, this mode won’t work.
    4.Full processing (default)
    The full video processing pipeline is enabled. This involves a full conversion to 32-bit RGB and back, and the video runs through the current set of video filters.
    Advantages:
    ·All filtering options are functional.
    ·Any decompressor-compressor pair can be used as long as the decompressor outputs some form of RGB and the compressor accepts 16- or 24-bit RGB.
    Disadvantages:
    ·The slowest mode.
    ·Requires the most memory, since all images must be decompressed to 32-bit RGB, and then converted back to a form suitable for the compressor.
    Audio->direct stream copy
    File->save wav (save as .ac3)
    Use beslice(included in besplit) or ac3fix to fix the ac3 (virtualdub adds wav headers).
