I am tiring to encode an svcd with selectable subs using sefy's backup guide. Everything goes just fine till I come up to the encoding part. I open tmpgenc and try to open the frameserve avi from vdub and tmpgenc says that it is an unsupported avi. I have frame served with vdbub before when I cap with huffy and re-encode to mpeg, but this time I am having problems. any help would be appreciated. thanks
I Don't know if my guide is the best option for Selectable Subtitles, as i've never done that before, my guide shows Permenent Subtitles, so I hope you know what you are doing
Anyway, regarding the Unsupported file problem, have you made sure the Frameserved file is .VDR ? also, make sure you used the AuxSetup to install the AVIFile handler before you start frameserving.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Hardcoding subs problem
By jliggett in forum SubtitleReplies: 3Last Post: 3rd Feb 2011, 18:04 -
Problem with MKV and subs
By footclan in forum Newbie / General discussionsReplies: 3Last Post: 16th Jan 2011, 17:06 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Hardcoding subs problem?
By elliottpen in forum ffmpegX general discussionReplies: 9Last Post: 22nd Apr 2010, 18:24 -
Problem: authoring w/subs
By maumastoks in forum Authoring (DVD)Replies: 3Last Post: 19th Jan 2009, 10:02
