Hey just a few questions maybe you guys can help with?
1) When burning MP3's can I place them in the order I want to?
2) Is it possible to not have pauses between tracks?
Thanks!!
409
1). No. You have to number them to get them in the order you want. (ie 01 - First song, 02 - Second), etc
2). That depends on your MP3 player, some will play with no gaps, some will have gaps. For example..I software Winamp player has gaps but you can get a no-gap plugin and also a crossfade/mix plugin -
try highlighting the whole selection of tracks on the burn side, right click with the mouse, go to properties and there you should see the amount of gap betweem tracks ( in seconds its normally 2 ) change the time to 0 and click apply, press burn and there you go !! This is ideal for burning mixtap cd's.
I've burned literally hundreds of CDs with Nero and all that I've ever had to do was drag the song to the queue and then drag them to the order that I want to burn in.Originally Posted by andydd
I would also suggest highlighting the all songs, right click, open properties, and then select the max setting under normalize (I think that is the correct term)
Lastly, I add an EQ filter, usually the "light loud". I find that this brings out the best sound in most mp3s.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
