Sorry 4 my bad English.![]()
I've insatlled the demo, run, dowload the zip, overwrite the exe, start tyhe demo... and after a few seconds a popup "DEMO EXPIRED" appears.....
MATTGuest
Hey,
You installed the demo then you used it and then you download the update of the demo?Greatings,
Yf -
MattGuest
NO, it was a NEW istallation, not an update.
I've also try UNISTALLING the demo, deleting the directory in program files and istalling it again.... same thing
Matt-Italy -
Is there a time limit on the demo license? If so then you can't install it after the license expires.
Greatings,
Yf -
MattGuest
by
http://www.svcd2dvdmpg.com/SVCD2DVDMPG/Software/svcd2dvd_demo.aspx
Demo #1: Expires 1st Oct 2003
so.. what's goin' on?
Try now!
My mistake
Convert expired WMA to MP3
By pchan in forum AudioReplies: 4Last Post: 20th Jul 2011, 10:44 -
DVD-Lab Pro expired
By jonghyunchung in forum Authoring (DVD)Replies: 7Last Post: 25th Mar 2010, 12:43 -
bd rebuilder expired
By davebarnes2009 in forum Blu-ray RippingReplies: 4Last Post: 4th Aug 2009, 15:59 -
DVD2oneX2 - Expiration expired (Is there....)
By JonnyPhoenyx in forum MacReplies: 5Last Post: 8th Mar 2009, 14:17 -
TMPGEnc has expired what do I do?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 14:55
