  1. I have a couple VOB files that was ripped from a DVD and i accidently delete the IFO file, so it wouldn't load into DVD2SVCD, is it possible to generate IFO files from VOB files? thanks.
  2. Just download IFOedit (free), run it and click on "create IFO's" then after that click on "get VTS sectors" and you're done.
  3. I kinda smell warez here. Why not get them off the orginal disk agian?
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
    I find IFOedit crashes when I try this.
    What I would try is load the vob into TMPG DVD author and reauthor with no menus etc.
    The software has a 30 trial.
    dlb.
