Just bouight this player (Elta 8899) off a German company on Ebay. It was described as multiregion, but is actually Region 2.
Have had no luck in getting any sense out of them for the remote hack.
SO, does anyone watching here have details of the hack for this player, or know where I can get it.
Got loads of Region 1 dvd's and can't plem them.
Any help greatly appreciated
Hi,
As this is your first post I have to assume you're not familiar with this site yet. So in an attempt to re-state the obvious:
1. Go to "DVD Hacks" in the "OTHER" category in the left pane menu.
2. Type "Elta" as a brand name and do a search. (I checked myself; the Elta 8899 is not listed, but some of the other Elta types are.)
3. Check out some of the ragion code hacks for the types listed - they MIGHT work on your machine, then again they might not. Careful though - I'm not 100% sure but putting in a code not intended for your machine might sc**w things up considerably.
I do not know the Elta brand by first-hand experience, so this is the best I can do. (My player is a Cyberhome CH-402 - bought after reading the reviews on this site. Region-free is dead easy with this one.)
If no luck here, check out the vast Internet
Frank -
Many thanks for the advice, but I did scour the forums BEFORE I posted.
Have also trawled the net until my eyes popped out!
I'm just annoyed at the misrepresentation of the company that sold the unit and have not had a suitable reply from them, apart from telling me that "It's easy using the remote control, just check the DVD-Wallboards" whatever that means.
Thanks anyway
Ok, have managed to get a hack that works (after many phone calls to Germany).
So for anyone else that has this model, here's the hack:-
1. Switch ON
2. Open drawer
3. Choose "Setup" on the remote
4. Move curser right to highlight "Preferences"
5. Type "49540" on the remote
6. Use down arrow & and select "0"
7. Press "Save/Play"
That's it
Multiregion code for Bose Lifestyle 18 series III
By pgoschebart in forum DVD & Blu-ray PlayersReplies: 7Last Post: 16th Feb 2022, 07:24 -
Insignia NS-2BRDVD hack code for multiregion Blue Ray and DVD?
By marcnz in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Aug 2011, 15:01 -
Hack code for multiregion DVD Samsung MAX DX75???
By ltcdrcharisma in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Mar 2011, 17:46 -
Technika DVDFAW08 Multiregion Code and XVid Compatibility Issues
By delta925 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 4th Dec 2009, 14:40 -
Multiregion code for LG DK7821P
By ieh4f in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Jul 2008, 16:11
