Ok.someone i know says that you can play .bin,.cue files on pc.ive got at least 10 of these can anyone help me???.also i want to burn them to dvd???![]()
You need to exctract (sp) them before you can play them.
svcd2dvd
Might be just what you are looking for to convert them to dvd so long as they are either vcd or svcd's.Not bothered by small problems...
Spend a night alone with a mosquito -
I use Alcohol 120% to mount the bin/cue files as a logical CD drive.
Works very well. -
I've never used Alcohol 120%, but you can do the same thing with DAEMON Tools - that is, mount the image as a virtual drive if you just want to play it. Just another option...
Open WIDE for Chunky!!! -
deamon tools <-- what you want!!
can be got from http://www.daemon-tools.net
site was down when i checked, but thats where i got it from, you have problems pm me
this program creates virtual cd drives on your pc
so u can load the .bin and .cue file and use um on your pc without burning,
as if you burned the cd on to a blank and inserted it in to a spare cd drive
you can set up to 5 virtual drives i think, very usefull for say 3cd svcd films
i hope this is helpfull to you, and is what you was lookin for
enjoyFrom The End To The Start It Begins In The Middle -
If you want to burn them to SVCD, Nero, and some other programs will burn the .bin/.cue onto a svcd so it will play in a dvd player. If you want to make any changes to the coding of the film, you can use ISOBUSTER to extract all the MPEG frames with audio out of the mpeg folder of the .bin.
If you extract and want to put on dvd, you will need to encode to dvd format standards using tmpgenc 2.5, then author and burn to dvd.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
