I have a Tivo that I have upgraded to a larger drive by saving the software image and then tranfering it to a new larger hard drive. I was contemplating buying a Panasonic DMR-E80 and was wondering if anyone had any thoughts or experience on how to do something simular with it?
-docbrock
Well, if it is like the HS2 I have, then No... you can not successfully update the drive... yet.
You can stick a new drive in the HS2, but it reformats it to 40GB (No matter what size drive you stick in).
Check out this site for more info.
http://www.thewholewideweb.com/forum/forum.asp?FORUM_ID=27
Oh yea, the post that says it is a success, really goes no where.
Later,
Tearren -
Might surprise some, but you don't need tivo or a recorder to record tv programs, you can use snapstream.com 's software on your PC to do the same thing. It's not free but there is a trial. Also try clicktv.com if you need tv listings.
Upgrading drive in Pioneer DVR-633H-S
By scotty123 in forum DVD & Blu-ray RecordersReplies: 18Last Post: 27th May 2016, 17:27 -
Upgrading SKY+HD Hard-Drive
By snadge in forum DVB / IPTVReplies: 0Last Post: 26th Mar 2009, 07:35 -
Upgrading hard drive in JVC DR-MX1 ?
By dwebb210 in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2007, 14:28 -
Pioneer 340 as replacement for Panny DMR-E80?
By LynnL in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Jun 2007, 14:04 -
Panasonic E80 hard drive crash
By csanders1962 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th May 2007, 18:57
