Results 1 to 9 of 9
PS2
  1. Anybody know how I can bypass the parental code on the ps2, cuz I forgot my last password, and of course I need that one to cahnge it.
  2. Member Devanshu's Avatar
    May 2003
    Try unplugging the console and maybe that'll work. See, this is exactly why I kept that code 0000. How could anyone forget that?
  3. Originally Posted by Devanshu
    That's the stupidest combination I've ever heard in my life. That's the kinda thing an idiot would have on his luggage.
    sorry couldn't resist. Free internet browser cookie for the person who guesses the quote. No googling
    Anyway, Try entering 7444.
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  4. if unplugging the ps2 from wall doesnt work (which it wont) and using the default code doesnt work you're going to need to remove the internal battery.. just remove the 8 or 10 screws from the bottom of the lid, remove the lid.. but when you are removing the lid, do it slowly because there is a cable running from the ps2 to the reset eject switch.. if you screw up the cable, you wont be able to initialize your ps2..
    anyhoo.. once you get the lid off, the battery is located on right side of the dvd-rom drive, use a small flat blade screwdriver and take it out. it will lose the password and give you an option to reset it.. it will also lose the time, but you can set that yourself.
  5. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    While you have it open, would be a good time to put in a mod chip.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  6. not if you dont know what you're doing.. removing the lid & battery is a pretty simple procedure.. soldering a modchip on to the motherboard is completely different.
  7. ya it wont work if ya unplug it, ive tried it before, but ill definitly try reseting the password.
    Think ill have a hell of a time trying to find someone who installs modchips though.
    thx guys!!
  8. Member Devanshu's Avatar
    May 2003
  9. Just so you don't think I am making fun of you Devanshu, that is a quote from the movie Spaceballs. The combination to the airshield was 12345. Then after Darth Helmet said that, the president walks in and says "That's the same combination I have for my luggage."
