I wanted some opinions on getting rid of macroblocks completely. I captured off VHS to 352x480 with MJPEG with a setting of 19. I used TMPGEnc to encode the file with 2000 as the min, 4000 as the average and 5000 as the max. There is an explosion in the video and even with these settings it's still kind of noticeable in it. Do I need to get crazy with the bitrates and do something like 2000 min, 6000 avg., 8000 max? I thought 352x480 capped out at about 5000? Others have said it's 4000 is where it caps at. I'm planning on moving this onto DVD when I get it all correct.
I ran these video files through Bitrate Viewer and the most anyone of them got up to for the peak value was about 4800. So, I think if I up the max, it's not going to do any good, since it's not even hitting 5000 on the max. I guess what I have is the best it can do.
what kind of motion detect settings are you using? a quick explosion might be relying on the bitrate from the previous frames and didn't adjust quickly enough. your bitrates seem adequate for half resolution, i don't think bitrate is the problem.
Using TMPGEnc goto the GOP Structure tab.
Select : Force Picture Setting then press [setting]
Locate the frames with the explosion and manually set the bitrate.
A real pain since you will need to reencode but before you do the who movie just do a portion of it using [source range] under the "Advanced" Tab.
High Quality At Low Bitrate?
By sanosuke in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 08:21 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 10:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
high bitrate h.264 looks like junk???
By RadicalxEdward in forum Video ConversionReplies: 14Last Post: 12th Jan 2008, 20:38
