I reinstalled xp on my system last week and ever since have been unable to get either of the programs to patch elementary video streams. I have tried this on both svcds and vcds (ntsc). Any help would be appreciated.
Results 1 to 10 of 10
adi_001Guest
I got some questions:
1. Did you run all the new updates?
2. did the same batch (exactly the same files) work before the reinstall?
3. Which versions did try?
4. Did you install .net framework 1.1?
5. Can you give use the log of the error you got?Greatings,
Yf -
adi_001Guest
In response to yf2001usa:
1. yes
2. yes - although the 1st time i did a straight to dvd-folder output, which worked fine.
3. i've tried both svcd2dvd and svcd2dvdmpg+
4. yes
5. i shall try again tonight, and select the log generation tool - although it was my understanding that a log was not given unless the process completed - in my case it simply hangs, and goes no further upon reaching the patching stage. -
log is still generated regardless of success. It is located at:
C:\Documents and Settings\Chris\Local Settings\Application Data\Badgersoft\SVCD2DVD\1.5.1336.21117\svcd2dvdlo g.txt
adjust build number & username accordingly.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
adi_001Guest
i just tried encoding 5 svcds with elementary streams and patching the headers... the first one seemed to work ok but it died on the second... here's a link t the full log: http://www.plasticunderground.com/docs/svcd2dvdlog.txt
adi_001: I have a build for you to try. Please email me.
adi_001Guest
Thanks Chrissyboy - great job as always
Also bigthanks to yf2001usa for tips and advice... This forum is great
adi_001Guest
chrissyboy - a new problem has arisen from the new build you sent me - the right hand edge of the video image now flickers and produces a lot of blockiness, and the audio stream sounds like chipmunks on speed...
Complete Video Converter?
By suharsh in forum Video ConversionReplies: 3Last Post: 27th Jan 2008, 12:37 -
SVCD2DVD won't not turn off computer when it is done.
By vn1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 11th Dec 2007, 04:59 -
TMPGEnc Plus won't complete batch jobs.
By Timex in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2007, 00:13 -
SVCD2DVD won't launch on my XP laptop
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Oct 2007, 10:29 -
SVCD2DVD won't launch after latest Windows Update of MS .net framework
By starkraving in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Jul 2007, 04:42
