Is there a way to copy (X)VCD to your computer so that you can play it from your comp, but you can also burn it to disc later?
Results 1 to 10 of 10
"Smoking kills. If you're killed, you've lost a very important part of your life."
copy the dat file
but if its on a cd - why not just play it on the cd?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks, if I use ISO buster, will I lose picture or sound quality if I turn the VCD into a mpeg?
"Smoking kills. If you're killed, you've lost a very important part of your life." -
I have done this successfully.
Go to windows explorer....explore vcd....look for biggest file among the disk(remember the name of file extension)...copy it onto HD prefferbly... C Drive....)...open command prompt also called MSDOS....go to c drive (C:\) and type this command "ren xxxx.xxx to xxxx.mpg"....you have file that is mpg....
GoodluckDon't waste your media. Burn it on re-writable media first. -
The DAT file in the MPEGAV dir is not exactly a MPEG1 file. You should re-generate the MPEG1 file with VCDGear or a similar program (I use VCDEasy). You can store the MPEG1 file and re-author it as necessary.
If you don't want to play the VCD from your CD-ROM drive whatever reason but want to maintain the fully authored disc. Rip an ISO image file to the HD then mount it with Daemon tools when needed. This way you can reburn the image to create a new VCD with the same authored menus/chapters/etc. -
I agree. Simply make a CUE/BIN image or the CloneCD image of your S/VCD and use Daemon Tools to mount it as a virtual CD when you want to play it. That way, when you reburn the image, it will be a near replica of the original disc.
Regards.Michael Tam
w: Morsels of Evidence -
Thanks for all the help, but near replica? Does that mean that there's still going to be some quality loss just not easilty detected?
There may be some unreadable sectors on the original disc that can't be corrected --> hence "near" replica. Assuming that all sectors can be read, then it will be perfect replica. In any case, make an image first is as close as you are going to get to making a perfect copy (be there unreadable sectors or not).
Regards.Michael Tam
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 22:56 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 13:06 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
PVR 150 won't do VCD on new computer
By darwin-t in forum Capturing and VCRReplies: 9Last Post: 27th Mar 2008, 15:29
