Hello,
I'm hoping someone can help me because this is really starting to get frustrating.
I bought a dvd200i a few days ago and when it arrived and I had installed it the computer recognizes it as a dvd200j. It still says 200i on the front and everything else seams to match up.
The main problem is I'm trying to upgrade the firmware to 1.51 but it isn't allowing me to do it. It can't read the 200j to update firmware!!!!
HP firmware install programs do not work nor does the region free firmware patch work installed via Rflash. It rejects it all.
Can someone please help? Thanks.
I've not heard of the 200j, sounds fishy. There's a 215i... Regardless, I recommend that you do NOT install the 1.51 firmware update unless you are currently experiencing problems with the drive (which you did not indicate). I have the 200i and I've had nothing but problems since I installed the firmware update. Unless you have problems DON'T UPDATE!
Good recommendation, I second that. If it ain't broke, don't jack with it.
The "j" is nothing to worry about. I have this same drive and it was recognized as a 200j by Windows XP.
Hi, If you do not have any problem with your drive It’s not recommended to upgrade the firmware, but if at the end you decide the upgrade (like I did) you may want to upgrade to the latest 1.64 Firmware for Ricoh 5125 type (2.4xDVD+RW/+R) burners. Many burners sold by SONY, MEMOREX, HP, AOPEN and others fall in this categories.
I upgraded my 200i to the latest Ricoh 5125 firmware and everything is working great.
If you are interested follow the next guide:
https://www.videohelp.com/forum/userguides/174580.php
you could use this guide to flah the HP200i to 1.51 RPC1 firmware.
If you decice to continue using your current firmware (RPC2) you could try DVD region free to watch movies from any region without trouble. Look this utility at http://www.dvdidle.com/dvd-region-free.htm -
One reason to update the firmware to 1.51 is that you can use 4x media. It will still write at 2.4x.
Mike
Lite-on DD-A100GX firmware upgrade?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Feb 2011, 03:45 -
How to Upgrade firmware of Samsung MM-DG25?
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 6Last Post: 2nd Feb 2011, 14:25 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 06:50 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 18:45 -
How to do firmware upgrade for a DVD Player
By Tiger_Lion in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2007, 00:33
