I have a .mpg video clip, i think its mpg 1, but When I play it the aspect ratio is really messed up. Like the clip is too wide so the clip looks stretched horizontally a lot. Is there anyway to fix this? Thanks
If it's mpeg2, (and maybe mpeg1 too) there's a value in the file header that tells if it's 16:9 or 4:3 (or some other format). If you get horisontally stretched images, then it sounds like a 4:3 mpeg, set to 16:9.
Someone told me pulldown.exe might let you change this without reencoding.
/Mats -
We need a lot more info. Where did you get the MPEG from, is it MPEG1 or MPEG2, what's the resolution, what do you want to do with it (watch on PC or burn to x(S)VCD or DVD).
Remember a correctly encode 4:3 or 16:9 MPEG to be authored to DVD will not look right on your 1:1 DAR PC screen.
Vob2Mpg Pro problem with extracted MPG aspect ratio
By Spoon_Lover in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Oct 2010, 03:20 -
convert .mov to flv video - ascpect ratio messed up
By lilly333 in forum MacReplies: 13Last Post: 23rd Jan 2010, 08:30 -
Bad .vob .mpg file playback, colors messed up
By lindylex in forum EditingReplies: 2Last Post: 30th Dec 2009, 09:56 -
Odd Aspect Ratio Problem in mpg files
By nerys in forum EditingReplies: 10Last Post: 14th Nov 2007, 12:45 -
keep aspect ratio?
By Dunkan21 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 13:27
