Well, I am new to this whole DVD-R thing but I have been doing VCD and SVCD for some time. I was wondering if you guys could help me out. I am creating a DVD from an AVI DIVX file and I have already done all the conversion and everything. The problem is that the video is too big to fit on one disk and I was wondering how I could get it to fit without compromising quality all that much. I have already constructed the menus with DVD-lab and am ready to author but I need to fit it on one disk. So I was wondering how I would go about doing this? Should I just re-encode from the AVI or should I compile the DVD as a finished product and use some program like DVD Shrink, DVD2ONE, etc to make it fit on one disk? How should I go about this? I could just re-encode and make a whole new video file if that produce better results but I would need help with setting up the custom settings for TMPGEnc. Note that I used custom settings in the guide “Configuring TMPGEnc for high-quality, DVD-compliant MPEG-2” with basically all the best settings. If someone could help me I would love it.
Thanks,
Slice
Results 1 to 13 of 13
I think you answered you own question.
Either transcode the finished product or re-encode the source so it wil fit.
I personally beleive that the best solution would be to re-encode the original source. I've found that I get better quality that way. -
so what do you think would be good settings for the VBR ES video stream?
thanks,
Slice -
Here is the info:
this should be sufficient but if you need any other info tell me what it is.
well, here we go...
Rate Control Mode: 2-Pass VBR
Aspect Ratio: 16:9
Resolution: 720x480
Video format: NTSC
Frame Rate: 29.97fps
Average Bitrate: 6000 kbits/sec
Max Bitrate: 8000 kbits/sec
Min Bitrate: 4000 kbits/sec
P picture spoilage: 0
B picture spoilage: 0
DC Component Precision: 10bits
Motion Search Precision: Highest Quality
NOTE: Current file size using these settings is 4.73GB; also NOTE that this is only the video it is a ES (Elementry Stream) video; Runtime is 2hrs 11min
that should be enough data
Signed,
Slice -
You have no choice but to re-encode the video. Use a bit-rate caclulator it is essential.
http://www.wiredinc.com/bitrate.html
Using the data you provided, you will have to lower your bit rate by a lot.
Assuming 448khz audio (usually dolby digital 5.1) you need an average bit rate of 4.08 mbits/sec. It is not necessary to use the highest quality setting in TMPGEnc when using bit rates above 3-4 mbits/sec. It hardly improves the image quality and increased encoding time by tripple or more. Use Motion Search Estimate it will look almost exactly the same.
TMPGEnc tends to be conservative in its encoding so you can probably increase the bit rate to say 4500 mbits/sec. If the movie has very little fast motion scenes than the file size will be much lower than estimated. -
that bitrate calculater sucks! it doesnt even work or out put a value so could you link to or reccoment a good program based bitrate cal?
PS: what do you reccomend for max and min bitrates?
thanks -
I get good results with the bitrate calculator on this site as well, I highly recommend it.
what to do after shrinking this video....
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2011, 09:05 -
Shrinking with Toast
By danielmak in forum MacReplies: 3Last Post: 22nd Sep 2010, 18:37 -
Shrinking Down a Video
By niteghost in forum Newbie / General discussionsReplies: 8Last Post: 12th Aug 2009, 07:58 -
Shrinking an AVI
By Squid_uk in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 16:33 -
Baffled by this one guys 'n gals....
By TheGMan in forum DVD RippingReplies: 5Last Post: 8th May 2008, 08:21
