I have created the DVD using DVD-Lab (great bit of s/w! & thanks for the help to all!)
When I try to play it in PowerDVD or my standalone - It won't play. I think that there's files missing. Can you look below and let me know...
Nero said that there were files missing along the lines of video_ts.ifo & video_ts.bup - shouldn't DVD-Lab have created these?
My movie consisted of the original DVD clip and a menu with one button but displaying contact details (easier than mpeg stills etc etc)
TIA
Pete.
Directory of C:\WINDOWS\Profiles\Pete\MYDOCU~1\PM2\IMY\working cut\AUDIO_TS
07/09/2003 10:34 <DIR> .
07/09/2003 10:34 <DIR> ..
0 File(s) 0 bytes
Directory of C:\WINDOWS\Profiles\Pete\MYDOCU~1\PM2\IMY\working cut\VIDEO_TS
07/09/2003 10:49 <DIR> .
07/09/2003 10:49 <DIR> ..
07/09/2003 11:25 81 Default.PLS
07/09/2003 11:24 12,288 VIDEO_TS.BUP
07/09/2003 11:24 12,288 VIDEO_TS.IFO
07/09/2003 10:49 565 VIDEO_TS.lnk
07/09/2003 11:24 47,104 VIDEO_TS.VOB
07/09/2003 11:24 18,432 VTS_01_0.BUP
07/09/2003 11:24 18,432 VTS_01_0.IFO
07/09/2003 11:24 98,304 VTS_01_0.VOB
07/09/2003 11:24 194,560 VTS_01_1.VOB
9 File(s) 402,054 bytes
Results 1 to 12 of 12
From what I see, DVD-Lab did create the files you mentioned, they are in your folder.
Question is, did you drag all the files needed to the VIDEO_TS folder?
Another question, did you accidentaly drag the files to the root of the DVD and not drop them into the VIDEO_TS folder?
I'd check those 2 things. -
Most software DVD players need two things:
1. A VIDEO_TS folder (yes all caps) located on the root drive
2. A VIDEO_TS.IFO file
DVD Lab created some extra non-standard files (VIDEO_TS.lnk & Default.PLS) which could be erased. However I do not see the VIDEO_TS.VOB file which is the first thing that the DVD player will try to play (look to the left under what is DVDR). -
Just a wild-ass guess here. It might have something to do with the space in the "working cut" directory name. I notice that your list displayed the shortened name "MYDOCU~1" which is usually used when an application doesn't like long file or directory names, especially ones with spaces in them. You might try changing the name of the "working cut" directory to "working_cut" or "workingcut" or something shorter without a space. I don't know exactly what errors you are getting, so this is, like I said, just a wild-ass guess.
What I did was:
1) Import the files into the asset window from the DVD I wanted to copy.
2) Selected Demux to give me the AC3 audio and video tracks separate.
3) Created a menu with a link to the movie for a single button and a 20sec timeout on the menu to the 1st (and only) clip.
4) Tested the Menu using the simulate option
5) used Project / Compile DVD.
So the Compile option has created these files in my \working cut directory as they appear in the start of this post.
Am I following the correct procedure? I think I am according to the on line help.. but any advice on things I may be missing - greatfully received. I need to get this cracked today by 1700hrs GMT or I'm right up the creak...
Pete -
Can anyone also tell me when I use PowerDVD to preview the author, what is the process for starting the movie.
I've been using file mode and selecting each file until something happens. What's the best file to start with to get the menu up and navigate from there?
Pete
Still need an urgent answer to my previous message. -
for your 2nd question the file is: Video_ts.ifo
in PowerDVD:
Open with "Open DVD file on Hard Disc Drive" and browse to the ifo file = Video_ts.ifoThere's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
You're welcome. :c) Good luck with your other question.
My problem is now:
I've got DVDLab to do a test compile (very basic mpeg image) with a simple menu of 1 x button.
Once compiled (and no errors), running the video_ts.ifo file has no effect in PowerDVD.
If I load the directory into DVD Shrink, I can see the menu. The menu functions correctly when viewed in simulation mode in DVD LAb.
HELP!!!
Pete
cant play galaxy s2 created video in windows when file size over 2gp
By mrhawks in forum Portable VideoReplies: 6Last Post: 18th Jun 2012, 09:50 -
DVD created with Panasonic DMR EZ 485v doesn't play back on computer
By gray9965 in forum Authoring (DVD)Replies: 2Last Post: 5th Jan 2010, 15:23 -
File created with sub2divx will not play on vlc or windows media player
By brattychiq in forum SubtitleReplies: 0Last Post: 23rd Jan 2009, 10:32 -
How to Play AutoGK Created Subtitles
By 888888 in forum LinuxReplies: 3Last Post: 6th Feb 2008, 18:19 -
Why wont windows media player play any audio from my created dvds
By thnkbg in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2007, 11:30
