on the intalation instructions it asks:
1. COPY README.WRI TO THE *ROOT* OF THE PARTITION FROM WHICH YOU INSTALL
aint got a clue wot i need to do, anyone know?
cheeRS
That's the problem with pirated software . . . lousy documentation.
What it means is that if you are installing from the C: drive, copy the readme.wri file that is one of the installation files to the root directory of the C: drive (ie, not to a folder in the drive, to the drive above the folders) -
of course i would had bought the software if i could
thanks Nolonemo, worked a treat, cheeRS -
you CAN buy it -- it is part of DVDA from sony (sonic foundry) and the same price ... but now comes with mpeg2 encoding also ...
therefore what you have is warez ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i never knew that, i read it wasnt avaliable any more....
anyway it dont work for me, crashes when i try n convert a wav 2 ac3
cheeRS anyway
Soft Anti-copie
By youneslalami in forum ProgrammingReplies: 8Last Post: 30th Dec 2011, 23:46 -
what edit soft for old pc
By runnernorth in forum EditingReplies: 12Last Post: 1st Mar 2010, 04:33 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43 -
Soft Sub to Hard Sub
By taylordotcom in forum SubtitleReplies: 1Last Post: 20th Feb 2008, 02:35
