How do I convert .MOV files to .MPG files? I really wanna download a lot a .MOV files since I have a slow isp. And I want to burn it to a VCD using Sefy's guide.
Hi,
If you got Quicktime 3 Professional or later
Open the .mov file with it then export it to avi and use full uncompressed or if you don't have the room use huffy codec then convert the avi with tmpgenc using the template you want to use.
or you can get a quicktime plugin for tmpgenc at this address "http://descargas.granavenida.com/vcdspain/down/qtreader.zip" to convert .mov to .mpg using the template you want to use.
Hope this helps
TurboRunner
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
help -No sound when converting .mov files
By bloke666 in forum ffmpegX general discussionReplies: 0Last Post: 11th Dec 2011, 11:48 -
Converting or Joining MOV files
By theWallflower in forum Video ConversionReplies: 3Last Post: 8th Apr 2010, 07:00 -
Batch Converting MOV Files
By thomasj in forum LinuxReplies: 3Last Post: 25th Dec 2009, 14:50 -
Converting .mpg-files to .vob-files ?
By stuckinsnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 09:11 -
converting .mov files to something I can use
By weazel_k in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 16:46
