I have a home movie (B.C. Canada vacation) that I put on dvd-r. I want to give my sister a copy but she has a plus r drive in her pc. Will the plus r drive (new Dell pc) read the files on the minus r so she can burn a copy for herself. If not does anyone have any ideas? (it would be kind of hard to email 3.75 gigs)![]()
Thanks for any help
Does your sister have a DVD ROM or a writer? I haven't seen any DVD ROMs that specific + or -, so I'd think they all read both (although maybe some older ones wouldn't read +R if it wasn't around when they were manufactured.
If she has a writer then I would guess that the answer is still yes. I had a +R writer for a while and it would read (but not write) +Rs. -
My plus drive reads any DVDR(W) medias
If you know the name of the burner click here to check it
https://www.videohelp.com/dvdwritersYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Thanks for the replies
the dvd burner is a dell dvd+r/w
I went to the dell site and looked up her Dimension 2400 Pentium and it doesn't give a brand name for the burner but i will try it out and see what happens. -
If she is not going to try to burn to a -r disk she should have no problem simply reading it. They should both read either format.
or you send her a data disk with the video file on it, she will be able to read that!
If you can read a data disk you can read a DVD-video disk! It's the physical media compatibility that is being questioned, not the file system.Originally Posted by RabidDog
Don't read DVD-RW disc
By Phoenix 37 in forum DVD & Blu-ray WritersReplies: 7Last Post: 28th Jun 2011, 12:33 -
"can't read disc, check disc" problem
By ttheb1 in forum Authoring (Blu-ray)Replies: 1Last Post: 13th Jun 2010, 07:34 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
can't read 16x disc
By jonij in forum Newbie / General discussionsReplies: 7Last Post: 15th Dec 2008, 03:35 -
Help my drive cant read?
By mad_max911 in forum DVD & Blu-ray WritersReplies: 13Last Post: 30th Jul 2007, 12:24
