Ok,, as the topic reads,, I've been capturing all of the episodes of my favorite show, cleaned out the commercials and encoded them into DIVX format. Now I got roughly 20 episodes and I want to throw them onto a DVD keeping them in DIVX format. I would like to create an autorun menu like you would get on a regular dvd and then be able to access all my episodes. What's out there that's simple to use, but also has some features to it?
I do not know of any programs that will allow you to create a menu pointing to DIVX files and play them. The best thing I could think of would be to create a small program in VB, Delphi, or C++ that is launched when the disc is autorun to display all the contents of the disc.
As far as the autorun goes, there was a post on here not too long ago that addressed this issue. I'd suggest a forum search. -
Well, I would assume it wouldn't be that difficult to access the Divx files from a menu. Just click on it and it should open up Windows Media or whatever your default DIVX program you use. I guess maybe what I'm looking for is a Data Menu that looks and feels like a DVD menu?
Also,, I did a search,, and didn't see anything useful
making a compilation vid from various file types/sizes
By pooksahib in forum EditingReplies: 4Last Post: 13th Jun 2011, 16:39 -
Easiest software for compilation, cutting/joining?
By jiopi in forum EditingReplies: 0Last Post: 14th Oct 2010, 13:31 -
Making a DVD compilation - MPEG2 to DVD problem
By Dingler in forum Newbie / General discussionsReplies: 11Last Post: 1st May 2009, 14:40 -
Making compilation DVD?
By chronic777 in forum Authoring (DVD)Replies: 8Last Post: 19th Jul 2008, 13:19 -
Putting text over a video (making a compilation RATM DVD)
By Salva Veritate in forum EditingReplies: 4Last Post: 1st Sep 2007, 14:52
