I want to capture a football game with my ReplayTV and also record the radio broadcast on to my computer and then mux the audio/video together.
What would be the best way to do this and properly synch the files?
Also, what bitrate settings and format should I record the audio at?
Thanks a bunch,
Jason.
you are probably going to want to use a video editing program to get the sync right.
(although, how tight do you need it in sync? how much "game sound" do you get in a radio broadcast?)
if I were going to do this, I would capture in avi format, lightly compressed (Huffyuv or MJPEG), capture the audio as a wav file, and import both of them into the editor.
I would delete the original audio track from the avi, and lay in the wav file from the radio. I would then try to find some action that I can correlate with the video, so I can use that to sync. (maybe a referee calling a flag?)
once you have it synced, either render it as an mpeg, or render it as an avi and encode it to mpeg in a different encoder.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Want To Mux MPEG-2 Video With .WAV to Create .VOB
By judicata in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2010, 16:07 -
MPEG Streamclip - MUX new audio file
By yonz in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2010, 17:59 -
MPEG-2 transport stream... how to mux audio/video?
By Navstar in forum ffmpegX general discussionReplies: 1Last Post: 19th Feb 2010, 17:22 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 10:10 -
Mux raw subtitle streams in a existing mpeg file.
By etvideob in forum LinuxReplies: 0Last Post: 14th Aug 2009, 02:22
