Does anyone know of a program that will convert a batch of TGA files to DVD Mpeg2. I know Premiere converts them but only to AVI as Premiere will not out put to Mpeg2. If i save as a AVI the goto Mpeg the result is bad. I would like to go stright from TGA to DVD Mpeg2. Thanks in advance.
I fail to understand why making an uncompressed AVI and then encoding
is any different from any other method as far as quality goes. -
You cannot do the formula below. It only excepts AVI sequence
If you want all tga as one mpeg2 file name all tga files as file001.tga file002.tga and so and select under enviromenal settings->open sequence files as movie -
It works fine with jpg...so I think it should work with tga also.Originally Posted by superwow
it (tmpgenc) DOES work fine with targa's --- you can also do it easy enough with Vegas or ANY encoder by loading targas into v-dub mod or v-dub mpeg2/ac3 mod and frame serving (works great -- i do it all the time to frame serve to main concept) ...
Mplayer image extract: my TGA is blue!
By RogerTango in forum Video ConversionReplies: 0Last Post: 30th Apr 2011, 14:11 -
ffmpeg tga to x264 command line ?
By krohm in forum Video ConversionReplies: 71Last Post: 6th Jul 2010, 03:01 -
stand alone dvd player and mpeg2 files
By sportflyer in forum Newbie / General discussionsReplies: 7Last Post: 17th Feb 2010, 08:34 -
DVD (VOB) files to mpeg2
By maxamillion in forum DVD RippingReplies: 7Last Post: 18th Dec 2008, 00:37 -
joining DVD mpeg2 files without re-rendering
By cheeseplease in forum EditingReplies: 4Last Post: 10th Aug 2007, 13:10
