I am trying to burn a VCD, but the audio has dropouts.
I thought perhaps if I reduce the audio bitrate, that would help.
But in TMPGEnc, I can't access bitrate...it's ghosted.
Results 1 to 11 of 11
Right click on Bitrate and choose unlock or load the unlock template in the template extra folder. But VCD must have 224kbit/s or else it will be XVCD.
Is the dropouts after you encoded?? and only on your dvd player or on your computer also? -
The dropouts are only on the DVD player. They don't exist in the source file, and they don't exist when the disc is played on the PC.
I have a Panasonic XP30 DVD player.
Is there anything I can do to eliminate the dropouts?
Thanks! -
it sounds like something is wrong on your dvd player.. but a good audio engine is besweet. maybe your dvd player doesnt like the media you are using.
Ok, now I'm really ticked.
I took the offending CD-RW up to my other CD player (Sony), that we used to watch VCD's on ALL THE TIME, and it doesn't recognize the disk.
Tried a different media...same thing.
I did replace my Yamaha CD burner a few months ago with a Memorex.
Is there some way I can test that things are being burned ok? -
Do the authored discs play in your pc once you have burned them ?
Thanks, I'll try that.
It really bothers me that my Sony DVD player won't play these VCD's.
It makes me think that there is something going on with either the burner (Memorex 52Maxx) or the software (Nero).
As I said, I've watched hundreds of VCD's on the Sony, and these VCD's were all burned with my Yamaha EZ2200 burner.
Now suddenly, the Sony doesn't even recognize the VCD's?
What else can I check? -
Try authoring with some other app than usual....
Try some other media than usual...
/Mats
Can you reduce video (MKV/H.264) Bitrate withOUT re-encoding?
By KushSmoka420 in forum Video ConversionReplies: 4Last Post: 14th Mar 2012, 04:17 -
How to reduce video bitrate of a MKV file?
By doronb2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd May 2010, 21:25 -
How to reduce bitrate of Xvid without recompressing or faster than this?
By dzsoul in forum Video ConversionReplies: 2Last Post: 18th Jan 2010, 05:59 -
reduce bitrate of mpeg file
By bradlewa2 in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2008, 09:32 -
How to reduce video bitrate ?
By Sean-- in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2007, 04:47
