After processing files through dvd2one, I can't get them to burn to dvd using Nero (any version). Nero will write approx 98/99% of the disk, but ALWAYS drops out when trying to write the lead-out track. The error message being 'cannot perform disc at once'.
To get a complete working dvd with menu, extras etc, i have to rip through dvd decrypter, process through dvd2one, then write a disc image using pinnacle's instant copy. Although this works fine, it takes absolutely ages to do the whole disc![]()
Any help on this appreciated.
I've tried different media etc, using Datawrite Reds/Yellows 4X, makes no difference.
regards
Artificial intelligence is no match for natural stupidity.
Hi,
I tried this today. Setting the target size to 4 gig which should have been small enough as nero only writes an additional 350+meg to the disc. Needless to say, the same thing happened. I'm gonna do another disc tomorrow and set the target size to 2 gig and see what happens, Think it's something to do with Nero and Disc At Once. Any other programme writes to the max and closes out no problem so I don't think it's the burner or the media.
regards -
Today I ripped a dvd and processed it thru dvd2one (full disc) with a target size of 2 gig. I then burnt the disc using nero. The disc burnt 100% then kicked out with the following error 'Sony DRUA etc Invalid Block Address'. In the past I have been able to play discs that did not finish properly as they always stopped somewhere in the credits. This disc wouldn't play as it said something about the disc title being incorrect.
When burning in Nero, is it necessary to rename the blank disc to that of the original before burning? never had any problems with old version of dvd2one except I couldn't do the whole disc or set a target size.
regards
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 10:31 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 02:12 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 15:56 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 18:18 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36
