DVD-r or DVD+r
What format would make sense for future use (ie:will one become the norm while the other becomes obsolete...like Betamax).
Results 1 to 19 of 19
"Today is only yesterdays tomorrow"
-r here as they are cheaper, only reason
I use both as i have a dual format burner. i usualy make my masters & personal dvd's on + but buy larger amounts of - as they usualy are cheaper but i tend to lean towards the + format 8)
When i bought my first burner i did'nt even realize there was a diff. between + & - until i tried to buy a spindle of - at my pc show
-R, because I wanted a drive that supports -RAM. The only drives at that time that supported -RAM were -R. Also because it is the officially supported format from the DVD consortium.
There are now fewer reasons to have to choose other than what you can get at your local store, or what you can get cheapest!Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
I burn DVD+R/W medias using DVD-ROM booktype that gives me total compatibilty (so far) regardless of burning programs (Nero and RecordNow,... all work for me) so I'm not planning to buy a burner that won't give me the same option.
Rewriting speed will be an important factor for me when buying a new burner, as I use it a lot.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
- R here
I don't see a reason to change that, plus -r is far cheaper where i'm from than +r is.
And i'm still using a 2 speed burner, again i don't see or need a reason to change that either.
I'll stick with my 2 speed burner untill it packs in, hopefully by that time we'll be able to get 32x speed or faster.
I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H -
"HACK THE PLANET - EVERYTHING SHOULD BE FREE"Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
DVD-R FOREVER!!!
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
I use DVD+RW, which I've hacked the Book type to be DVD-RAM (old 2.6/5.2 style), and burn with Mode2 and UDF 2.01. This gives me total DVD INCOMPATIBILITY!
:P
Scott -
DVD-R because thats what my standalone (Panasonic) dvd player will play....
Not bothered by small problems...
Spend a night alone with a mosquito -
-R, because the burner was on sale
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
DVD-R because DVD+R wasn't invented yet.
My strategy is simple : at home, I reused DVD-/+RW for testing and then burned DVD+R for archiving and for the master copy. At home, all my set top players, laptops and computers can play -/+RW and +R.
If I distribute copies to my family and friends outside of my home, then I burned with DVD-R for maximum compatibility and low cost.
That's my strategy. -
+R for the reliability , 4X speed , and its compatible with my three players . I cant find 4X -R discs with the reliability of those RICOHJPNR01 discs for around the same price 1.13 to 1.20 dollars U.S. .
Keep it on the big cam !
What format to use to burn video to DVD to be played in the UK (England)?
By jubbilee in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2011, 01:21 -
Burn from to DVD but what format to play on tv?
By Claxlast in forum Authoring (DVD)Replies: 5Last Post: 18th Mar 2011, 16:57 -
Are the AVCHD and H264 the only HD format to burn the HD DVD?
By coody in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2010, 22:47 -
how do i burn rm files to dvd format?
By sprilite in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2008, 12:41 -
I've got an animation I did in MPEG format and I want to burn it to a DVD
By el_cid in forum Newbie / General discussionsReplies: 6Last Post: 3rd May 2008, 14:11
