    Sep 2003
    Germany
    I captured from a pretty bad video source with Hauppage PVR and in the resulting mpeg file are audio and video not sync. is there a way to fix that, so I can burn that on DVD? I found no way to get the source a better quality, so are there any tools that could bring audio and video together again? I found no guide here so far, so maybe some of you can tell me what to do or where to find a guide. Thanx
    May 2003
    Pal Realm
    There are a lot of posts about synch problems. Do a search for "audio synch" in the space above this thread and you'll find a few day's worth of reading material. Good luck.
    (That's probably why no one has responded so far. The question's been asked and answered many times already.)
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
