I want to confirm if all PAL DVD Player can play NTSC DVD. Can you replyme with your brand, model and Country and indicate if can play NTSC DVD's.
i think the vast majority of PAL dvd players will play NTSC dvd's, but in order for them to display correctly on a PAL-only TV you have to output through RGB
For specs, see my details.
/Mats -
Every UK DVD player I have tried will play NTSC discs.
I do believe PS2 dont. I know my friends didnt play a region one, so i copied it..removed the region coding and it would play but with b/w picture. I do believe it mentions this on the 'region free' gadget you can buy for UK PS2s (it says you need a PAL/NTSC TV).
My H&B DVD-5415S Plays (Almost) everything I throw at it!!!
Wonderfull machine!!!
I guess most ESS-Videodrive equipped players support NTSC on PAL...
'HAG -
AFAIK, all PAL region DVD players will play NTSC encoded disks. Its what kind of signal they output, and what your (PAL?) TV can handle that matters.
There seems to be two choices of output signal, with some players offering both.
The 1st is obviously NTSC signals. In this case your TV will obviously have to be NTSC capable. The second is PAL-60. This, as far as I understand it, is a PAL signal exept it has a framerate of 60 fields per second for NTSC framerates. Again, your TV needs to ba able to handle this signal type.
It appears that many TV's sold in europe (for quite a few yaers) can handle at least Pal-60 and quite a few can also handle NTSC, even if it is not advertised on the box.
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Will a homemade NTSC dvd play on a PAL player?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 23rd Nov 2010, 04:54 -
Ntsc BluRay players play PAL(region-free) dvdr?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Nov 2009, 19:48 -
Portable Dvd Players...PAL/NTSC Friendly?
By Moontrash in forum DVD & Blu-ray PlayersReplies: 3Last Post: 25th Dec 2008, 19:41 -
Format free DVD-R (plays in both PAL and NTSC DVD players)
By Disco Makberto in forum Newbie / General discussionsReplies: 6Last Post: 22nd Nov 2007, 01:34
