  1. I seem to recall reading about a program/utility that lets you check what codec is used for a particular video file. I've search the forum and checked out the Tools section, but I can seem to find it. Does it exist and if so, what is it called?
    Thanks!
    Gil
    _____
    Have you heard Kazaa using the DMCA to remove Kaza Lite from Google because it claims Kaza Lite violated its copyright. How ironic is that?
  2. Here is one for AVIs
    https://www.videohelp.com/tools?tool=99#comments
    There are a few under both "codecs" and "other useful tools" take your pick
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  3. GSPOT is one of them. u can get it in divxmovies.com
    gspot allows u to detect the codes used for your video n audio.
    hope that helps.
  4. Yeah, that's the one (AVICodec). Hey thanks Solarjetman and hotsizzle. I appreciate the quick resply.
