When I play my DVDR back through my Toshiba topset and enable 'bitrate' to display, the bitrate display will sometimes kick up to 9.8 or at the highest 10.1. Is this a problem? How acurate is this? I thought there were supposed to be playback problems if the overall bitrate exceeded 9.8. I have no problems during playback but was concerned, should I be? The avg bitrate on the display seems to show between 7.1 - 8.6.
My source is .avi then I converted to .m2v + .wav using TMPGEnc using a VBR of 6000-8000, min set to 0. If this was true, shouldn't the max overall bit rate be more like 9.536 instead of 10.1?
ChachiFace
IIRC, the max bitrate for DVD is 10.08Mbps (I was corrected recently on this). This is the Video+Audio bitrate. The max Video bitrate is 9.8Mbps. As well as Video+Audio there is also a small overhead for other info.
How accurate? Not very. Just remember that a DVD player cannot even play a DVD with combined bitrates greater than 10.08Mbps.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 17th Jan 2011, 23:00 -
Bitrate question
By SuxRight in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 00:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 22:03
