I get this error: AVIStreamSetFormat failed
DVD movie being converted using DivX 5 as codec
Using DVD 2.2 to make the conversion
This error will come up and you have to start over. Hours wasted.
What are these errors and what do you do to correct in the settings to fix?
Screenshots
http://www.bustedcomputer.com/dvd/dvd.htm
I dual backup my DVD's to DVD backup for frequent use and to avi as an extra safeguard.. I don't have the fix but rather the same problem since upgrading from 5.05 to 5.1. I can add that it probably is not the fault of dvdx because I get the same error with DVD Ripper #1 and dvd Ripper IMTOO. Unless they are all based on the same basic code which was publically released by the author of DVDX. I have been very fortunate that it comes up in the first few minutes of the encode so at least I don't have to waste a lot of time.
There's not much to do but then I can't do much anyway.
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 12:40 -
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 08:14 -
Nero Error Msg - 'Prepare Session Failed'
By Dieseldog in forum Authoring (DVD)Replies: 0Last Post: 19th Dec 2011, 07:38 -
error writting failed, exception 8, status 31 text'CstarBurn_ScsiTransport
By raiden68 in forum Authoring (DVD)Replies: 6Last Post: 6th Feb 2010, 01:39 -
FAVC - Error (Fix VTS Sectors failed!)
By tim_ver in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2009, 02:16
