  1. I'm putting a 24 second AC3 audio track on my DVDLab authored menu. While the DVD plays fine, I don't get hear any music.
    I've made DVDs with menu music before using MyDVD, so it's probably not the player's fault.
    The way I made the AC3 clip was by ripping from a CD to WAV and then using BSweet to convert it to AC3.
    Any ideas?
    TIA.
    Greg
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    You need to drag the audio from the assets folder into the menu in DVD-Lab. If you did that and your audio still doesn't work, then check to make sure your AC3 file plays. You can play it in PowerDVD.
  3. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    I use mpa files on the menus at 48k. You can load 44k but dvdlab will offer to transcode it. Those always work for me.
    There's not much to do but then I can't do much anyway.
    Oct 2000
    This issue was addressed in the official DVD Lab forum. Sorry, I don't remember the answer, but it shoulden't be hard to find.
    Go there and search.
    I don't have a bad attitude...
    Life has a bad attitude!
